panasonic tx-w32r4dp engineer code
A
almofan89
does anybody know the engineer code for a Panasonic tx-w32r4dp 32" CRT tv.
The picture has become tilted and i cannot straighten it without the engineer code to access this menu :(
Thanks to anybody who can help
compo
go to the sound menu and turn the bass to max and set the treble to minimum exit the menu, now press -/v button on the tv set whilst holding the index button on the remote control this will give you service menu 1, the coloured buttons on the remote are use to move through the menu and change values, use the exit button to exit service menu.
be carfull as messing with the service controls can damage your set best to write the values down first then you can always go back to how it was set in the first place.
