Panasonic TX-P50V10 Box Dimensions
hdtvgeek
Hi chaps.
As the title states, I need to find out the dimensions to make sure it can get in the boot of a RS4 Avant.
Many thanks:)
LukeFoster2006
I've just measured one we have at work and it's dimensions are 140cm long, 92cm tall and 28cm wide.
Hope this helps Luke
GreenBars
Would you able to fit it in upright? It's not supposed to be transported flat.
hdtvgeek
Nice one chap, just need to get a tape measure out to see if it will fit. thank you :)
