Can someone help me please with getting my computer to show on the TV?
I have a Dell Zino, and it is connected to the TV via an HDMI cable. Am I missing something, as nothing shows on the TV. I have it connected to the 3rd HDMI socket.
on mine i just plug laptop into tv, go into the screen resolution settings in windows and click detect, then click "duplicate these displays" in the mutiple displays menu, also select on the tv's av the correct hdmi port
dude... are u sure u arnt expecting too much for 3D in televisions?? Try downloading the famous LG demo video, if the fish dosent pop up then, u can ascertain if theres a fault in ur tv.....
btw...3d in tv will never be that immersive like that in theatres
Just found this Gigaworld - Panasonic DYWL10 (alternative)
It has a comprehensive list of suitable tv
If im not allowed to post the link then im sorry but as im not sure ill leave it till i get told off
reaper12 said:Thanks, but i am in ireland, and i just want to try a wireless dongle that i can get locally to see if it will work.
Can nobody take 2 minutes to tell me what software version they have on their tv please?
leedebs said:Think 1218 is the latest as I recall, this fixes the FBR's apparently
Has anyone found a cheaper alternative dongle for this tv yet?
reaper12 said:you might have to set the resolution to 720p or 1080i. Another thing make sure you have the right cables plugged in. Some people reverse them by mistake.
Buzz2985 said:Component from Bose to Scart to TV is ok though is it?
JayCee said:No, if you're using component out (Red, Green, Blue)...not to be confused with Composite (Yellow, Red, White) you need to connect to a component input on the Tv...not scart.
