Panasonic TX-P42GT30 self check failed
Discussion in 'Panasonic TVs Forum' started by sergeus, Aug 11, 2012.
  1. sergeus
    sergeus
    Aug 11, 2012
    4
    Hello!
    In Self check I have error - LAN - 01.
    What is the problem?
    Best Regards
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,922
    Sounds like the telly's not connected to your network.
  3. sergeus
    sergeus
    Aug 11, 2012
    4
    I checked all the connections. All connections - fine.
    Prior to that, there was a thunderstorm and TV gave 14 LED red blink.
    I corrected it, disable / enable the cable from the motherboard.
    But there was an error with LAN
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,922
    That doesn't sound too good.
    Does the telly actually connect to the net or not?
  5. sergeus
    sergeus
    Aug 11, 2012
    4
    TV connected to a LAN, but not on routore LED, there is connection. If you do the test in the TV menu, I get the error: check cable.
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,922
    A mooch on the net has revealed the following;
    14 blinks IR LED SOS A-Board
    A Board = Main AV Input / Processing
    I'm not sure if that helps at all though.
    And I'm not sure what to suggest apart from getting a repairman in or your dealer to look at it, if it's still in warranty.
    I wouldn't mention anything about a thunderstorm though.
  7. sergeus
    sergeus
    Aug 11, 2012
    4
    I was hoping that somebody has error codes self check.
    Can someone encountered a similar problem?
