Pharisee
Pics attached. We have updated the software and done a hard reset. The problem seems to persist.
Some bits I found on the internet:
Re: Overscan: Some TVs will label this as "Full," "Fit" or "Dot by Dot."
Other TVs, like Panasonic ... have an additional setting you must enable to get 1x1 pixel mapping. On many Panasonic TVs, once you've enabled "Full" you also have to select "Size 2" in the settings menu to eliminate overscan. Sneaky.
To access service menu:
The problem exists regardless of whether the Tivo box is viewed or UK Freeview (our national free-to-air service.)
I personally don't see the overscan on some channels / programs (like the HD ones) but the TV owner is adamant there is a Big Problem and is quite upset that a £1500 4-year-old TV may have to be sold off and replaced.
Any suggestions gratefully received.
Thank you.
- Press your Panasonic plasma TV’s “Power” button to turn it on.
- Press and hold the “Volume Down / -” button on your set’s front or side panel.
- Press the “Status” button on your set’s remote control three times while you are still holding the “Volume Down / -” button on your TV.
This issue started when our Virgin Media Tivo box had a 'green screen of death' and said it was trying to fix itself. We believe that box, or the new Tivo box we got as a replacement, did something permanent to the Panasonic's settings i.e. gave it a kick and traumatised it.
Thank you.
