Really struggling with finding an external USB drive for my Panasonic TX-55EZ952B.
I was hoping that I could just plug a USB 3.0 120gb sandisk USB stick into the USB 3 port so I could use it for live pausing and a small handful of recordings.
Is there a reason the USB stick wont work. I have so far tried formatting to NTFS, FAT32 and Linus Ext2. I have also deleted the entire partition then reformatted using different sectors per cluster ranging from 8 to 32. Still no luck!
My concern is that I dont want to pay for a usb hard drive by another manufacturer only to be back in the same situation I am now in.
Is there a list of external USB 3 hard drives or thumbdrives that has been tested and proven that they work?
I added a 64gb sandisk USB 3 thumb drive to a Samsung smart TV and it just worked so not sure what the issue is with my nearly top of the range OLED tv from Panasonic.
Thanks for any tips.
