How are you finding the JS9000 compared to the CX802 as these are 2 of the current tv's I am looking at?
Yeh the JS9000 is good, I had 3x 50CX802b's, they all had different issue's with backlight, and none of them seemed to display Red correctly, it would be Orange unless I used a colour balance other than Rec709 or turned the Red up manually to just below max.
I didn't want a curve which is why I went for the Panasonic originally, but after having 3 with similar but different issue's I thought it was time to try the JS9000 and it's great.
After a couple of hours I didn't even notice the curve anymore, and the extra hdmi socket comes in handy too.
Performance wise there is little between them, they both give a great picture, and neither seems to suffer with judder (which is important to me, as I am susceptible to that), and both have been pretty much clear of any DSE or banding, however there was a little clouding on 1 of the Panasonic's.
The only thing I really don't like about the JS9000 is the stand, but i'm not using that anyway, and the other thing is I would rather is was black instead of silver, but it's not the end of the world.
I would have been just as happy with the CX802b though, had it displayed Red correctly and I didn't have any backlight issue's with them.
