skillfulmmd
- Joined
- Aug 18, 2014
- Messages
- 21
- Reaction score
- 3
- Points
- 36
- Age
- 32
Hi there,
Sorry if this is in the wrong place
I recently purchased this Tv only to find that I can't use Netflix 4K or Amazon Prime Instant 4K streaming however I figured I would be able to use my NAS drive to stream 4k files however when ever I try to use the built in media player on the TV I get an error message saying that the " video resolution is not supported".
I made sure to check that the video file is the correct resolution and it the TV's built in media can see the file. at first I was thinking it was an issue with the old generic HDMI cable I was using but that wouldn't make sense as this is only plugged into the Pioneer receiver.
Is there a restriction on streaming 4k over networks?
Also I have my Virgin Tivo box plugged into the tv and it is only showing up as 720p/50Hz would this be down to my HDMI cable not being able to push the picture further than this?
Thanks in advance.
Thanks in advance.
