Panasonic TX-36PD50 or Tosh 36ZP46
Discussion in 'General TV Discussions Forum' started by Trevor spencer, Jun 23, 2005.
Tags:
  1. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    457
    +3
    hi im new here :)
    im thinking of buying a new TV either a tosh 36zp48 or panny tx36pd50 (discountinued) but ive located one :)
    also whats the difference between 36zp48 and 36zp48p
    i mainly want to play games on the TV and really need it to display NTSC 3.58
    also would i be able to put either TV on this stand
    [​IMG]
    its 900mm X 500mm
    any help would be great i own pretty much every games console about mainly US / JAP imports
  2. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    PD50 has been discontinued AFAIK..............
  3. Astaroth
    Astaroth
    Jun 22, 2004
    3,459
    2
    London
    +781
    The PD50 is damned heavy - check the manual or with the manufactures of the TV stand to make sure it is able to take the weight.
    With some stands they will only give a "suitable for widescreens up to X inches" rather than a weight (as with my stand) and so it is up to you if you want to take the risk and have to argue the case with the retailer/manufacture that it is not fit for purpose if it does break.
  4. Trevor spencer
    Trevor spencer
    Jun 23, 2005
    457
    +3
    hi thanks for the info , ive been doing a bit of research today and the TD50 is like 85kg :rolleyes:
    the Z3AV stand will only take max of 75kg so i looked into the tosh and that one weighs in at 75.9kg but im not sure if i want to take the risk
    damn shame as i hate the stand you get with the TV
