Panasonic TX-32PK25
Discussion in 'General TV Discussions Forum' started by Jock, Nov 25, 2001.
Tags:
  1. Jock
    Jock
    Does anyone have one of the above TV's ? (i'm considering buying one)
    If so, would you recommend it ?
    Also, I have read the review of the TX-32PK20 on this site - does anyone know how the PK25 differs ie what's the main difference in features ?
    Thanks,
    Jock
    :confused:
  2. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    I wouldn't go for a 32PK25, I have had many problems with them over the last few months (Moire, Vertical Noise, Shadowing, etc etc), to the extent that now I have had a refund. From the reviews they are getting, I would say the new 32PL10 would be a much better option, it has a different chassis, and hopefully none of the problems with the Euro 7 chassis. You should be able to pick one up for the same price, infact I've seen them cheaper than the PK25s in some shops.
    Hope you get a good one.
    Regards,
    Buckster.
