Panasonic tx-32ph40 TV compatible with progressive scan pal 50hz zone2 yes or no ?
Discussion in 'TVs' started by VEGA2003, Jan 30, 2003.
Tags:
  1. VEGA2003
    VEGA2003
    Does anyone know if the Panasonic tx-32ph40 is compatible with the 50hz signal in progressive scan PAL of zone 2 DVD’s.
    I know it works with 60 hz progressive scan with zone 1 DVD’s but what happen with 50 hz zone 2 DVD’s?
    Thanks for your answer.
  2. fuzzy
    fuzzy
    Sep 8, 2002
    40
    I thought pal prog scan output via component was at 60hz whether that was from zone 1 or 2. The difference is whether they are NTSC or pal.. i think! Perhaps someone with more knowledge will enlighten:confused: I hope so since my next purchase when funds allow is to buy a pal prog dvd player to go with my ph40:)
  3. raZorfish
    raZorfish
    According to available information the Panasonic model you are refering to is the first TV in Europe to support PAL progressive signal (625p@50Hz) input (via the component interface)!
    See thread "The ultimate CRT-based PAL TV?" for the only other model that supports PAL progressive as well (JVC's latest model).
    Which model you should go for I really couldn't say since I haven't seen any of them in real life performance. However, the spec of the JVC TV looks really impressive...
    raZorfish
  4. YellowCows
    YellowCows
    Dec 15, 2002
    141
    Yes, the panasonic is Pal progressive - compatible from its component inputs.
    Pal is 50Hz, NTSC is 60Hz. This is the same whether interlaced or progressive.
    HTH
    Moory:)
