Panasonic Tx-32pg50
Discussion in 'Projectors, Screens & Video Processors' started by sweezely, Sep 19, 2004.
  1. sweezely
    sweezely
    Sep 14, 2004
    70
    Hello, I've got a Panasonic Tx-32pg50 (pal) which has got progressive scan, but strangely has no component inputs. This seems odd as I'm under the impression that you only get progressive scan via components. Am I wrong, and if I am, does anyone know an inexpensive pal dvd player with progressive output through a scart?
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Hi and welcome to the forums!
    The 32PG50 does not accept into it a progressive scan signal from an external source, but can convert signals into progressive scan format for display using its own internal processing.
  3. sweezely
    sweezely
    Sep 14, 2004
    70
    Thanks, you've confirmed what I had suspected.
