Panasonic TX-32LXD80 + 4K firestick
JuddNb
Afternoon all,
I am attempting to upgrade from a second generation firestick to a 4K firestick on my Panasonic TX-32LXD80but have what looks like a boot-loop - upon turning on the screen alternates between a white screen with yellow lettering and a black screen with white lettering but just loops between the two. I have tried this on another TV (LG) (as well as ANOTHER the name of which escapes me) and it starts up first time. My understanding is that a 4K stick should work with this model . Does anybody else run a 4K firestick on a Panasonic TX-32LXD80 ?Any comments or suggestions very welcome.
rgds
Juddy
JayCee
Have you tried it in a different HDMI input?
Are you powering it using the psu that came with the Firestick or a USB port on the TV?
JuddNb
Hi Guys ..thanks for the responses...yes I've tried a different HDMI port and am powering thru the cable provided (plugged in to the wall socket). JayCee are you saying the TV is incompatible ? The older second gen firestick works in either HDMI ports ...would be greatful for any further comments.
Juddy
JayCee
What video resolution is the new Firestick set to?
Make sure it's no higher than 1080
JuddNb
Make sure it¡s no higher than 1080
Thanks Jaycee ...I wont be able to do that until Wednesday at the earliest as the other TV is elsewhere (and the only way I can access the setting menu) ...once I have changed the resolution will that setting then stick when connected to my TV ?
Thanks again
Juddy
JuddNb
No luck 😢 I changed the resolution (plugged to another TV that it does work on).
Also borrowed another 4K stick which works but alas the very same behaviour ...leading me to believe the Panasonic itself is for some reason incompatible with the 4K stick.
Thanks for the suggestions but unless anyone has any further advice I'll be sending it back to Amazon ....
JuddNb
Looks like it could be a firmware issue ... if anybody has any firmware update for the TX-32LXD80 I'd love to hear from you ...
thanks in advance
Juddy
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
