Panasonic TX-32LXD500 Questions
Discussion in 'Panasonic TVs Forum' started by rowbos, Sep 4, 2005.
  1. rowbos
    rowbos
    Jul 9, 2002
    290
    Minehead, UK
    +3
    Hi There, just a couple of questions on this device...
    1) Does it have a PC input available - this is not listed on the Panasonic web site description?
    2) Does it have a wall mount available to mount it flush onto a wall?
    This is likely to be used for an equal mixture of PC and CNN useage (via Sky) with the occasional bit of golf thrown into the mix.
    Cheers,
    Steve.
  2. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,623
    Have a look here to see the connections and the wall brackets information.
  3. rowbos
    rowbos
    Jul 9, 2002
    290
    Minehead, UK
    +3
    Thats great thanks, when it says PC input what does it mean though?
    Does the panel also have a standard VGA input - or do I need a cable to connnect VGA to one of the connectors shown on the link?
    Cheers,
    Steve.
  4. scw
    scw
    Jan 6, 2005
    212
    +4
    connect direct to standard D-sub 15P connector
  5. rowbos
    rowbos
    Jul 9, 2002
    290
    Minehead, UK
    +3
    Cool thanks.
    Steve.
