Panasonic TX-32DTX40 Display Query - Help
Discussion in 'Televisions' started by cheekymonkey, Apr 3, 2005.
  1. cheekymonkey
    cheekymonkey
    Got it delivered today along with the new Panny DMREH50 DVD Recorder.
    First impressions are that both are superb although I have one niggle with the TV so far.
    The channel indicator remains in the top left hand corner all the time and I would have thought that I could remove this option ?
    Have read through the (poor) instruction manual and tried walking through the menu options on screen but to no avail.
    Can anyone tell me if you can remove this indicator and if so, how ?
    thanks.
  2. avio
    avio
    Press the 'i' button on the remote.
    Sorry that only gets rid of the AV1,2,3 or 4 display.
    Just had a play with my set and can't get the channel number to stay showing.
    I'll have another try later if you can't find the fix.
  3. JayCee
    JayCee
    Jan 20, 2004
    19,744
    Lanarkshire
    +1,876
    Going from memory here but look for a button probably 3rd or 4th row down with a small square icon of a Tv screen with a small "+" in it.
  4. cheekymonkey
    cheekymonkey
    avio/ jaycee
    Thanks - :thumbsup: - I pressed the "i" button and yes it has gone ! :D
    It's always the simple answers in the end isn't it ?? Thanks again for your help - frustration removed and viewing pleasure increased. :clap:
