Panasonic tx 32 PB 50
Discussion in 'TVs' started by tigertimtim, Sep 10, 2005.
Tags:
  1. tigertimtim
    tigertimtim
    Mar 31, 2005
    650
    +287
    Hello,
    ive just took delivery of a second hand model of a Panasonic tx 32 PB 50, unfortunetly iam not getting anysound off the AV1 channel (sky scart connection), AV4 works fine with foriegn Satellite reciver, AV3 fine with dvd, also theres a distinct humming sound coming from the set , are theese common problems with this set ? must say PQ isnt as a good as my 28" Panasonic as well , any advice please ?
    Tim
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    It would seem that from a few reviews I've read this set falls below standards and is prone to a bad picture. While I'm sure that every set cannot be of the same low standard it does appear to suffer more than most.
    Did you check the TV before delivery?
