Panasonic TX-29F250 CRT - vertical bars in dark scenes
T
Toolman NZ
I just bought a new 29" 100 Hz Panasonic TV (TX29F250 bought and using in New Zealand), and have noticed faint vertical bars in dark scenes when using the component inputs to connect a Sony home theatre DVD player (DAV-DZ500).
In progressive mode (playing both PAL and NTSC disks) there is one main bar in the centre of the screen. In interlaced mode there are two bars - one near each side of the screen - with smaller fainter bars nearby. The bars are slightly darker than the normal black level, so they disappear if I turn the brightness control down (but then so do any dark scenes on my DVD).
The bars are also visible if I set the DVD player's background to black and stop the DVD player, so it's not the DVD decoder.
The bars disappear when using the composite connection.
I am using new 1 metre Monster component leads, so I don't think it is a cabling issue.
Anyone have any ideas on what could cause this? :lease:
HR_The_Butcher
I have a TX-29PS20F/P model, and a similar problem. Guess I'll never buy Panasonic again.
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
