Panasonic TX 29 PM1D, how to get service panel?
Discussion in 'General TV Discussions Forum' started by Stelio, Apr 17, 2007.
Tags:
  1. Stelio
    Stelio
    As you red in title.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    Your title doesn't make any sense :confused:
  3. Stelio
    Stelio
    sorry if i did some mistake, i'm not english.
    What i would ask is that: in this model of panasonic, how can i access to service panel, tv's menu hidden to consumer?
    It's very important because i have some problem with images and their geometry... :(
  4. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    What is the problem?
    It may be a fault and not correctable within the service menu.
  5. Stelio
    Stelio
    The Geometry view can be partially fixed by service menu, i know it for personal experience ;)
    Obviously, it can't be fixed totally (it's impossible for all the crt tv actually on sale), but only reduced. Anyway, Geometry it's not a fault, but a regulation.
    But service menu can't be reached normally, it's hidden, it isn't traditional tv's menu.
    Is there anyone who can help me?
  6. Medusa
    Medusa
    Mar 29, 2007
    103
    +3
    Hello Stelio,
    I think JayCee is correct in saying it might not be service mode set up.
    Grey scale is incorrect?
    Video fault? Tuner I.F Dry joints
    Check Electrolytic Capacitors in P/supply -primary and secondary stage.
    If it is service mode set-up try :
    Going on CH 60
    set sharpness to MIN
    hold Vol down on tv and at the same time Press Timeroff key on the remote.
    or try
    Bass to max
    Treb to min
    hold V down on tv and on remote key in INDEX key
    To reset press V down on TV and at the same time STATUS key on remote.
    Good Luck.
