Panasonic TX-28DTX UPDATE PROBLEM
Discussion in 'General TV Discussions Forum' started by andrewb150, May 30, 2005.
Tags:
  1. andrewb150
    andrewb150
    Feb 28, 2005
    87
    +6
    I have just tried to update my set (TX-28DTX) to the new software (V2.45), it downloaded fine, installed and then the screen went blank. I waited and nothing happened, so I turned off the set and when I switched it back on the Digital tuner did not work or let me retune it.
    - Is there a bug in the software? is my set kaput!
    - Has anyone else updated?
    - What should I do?
    The software says it provisional on this site but I didnt know that when I was told to update it:
    http://www.dtg.org.uk/retailer/download_schedule.pl
    Thanks in advance for any help or advice
  2. avio
    avio
    I've got the DTX40 model which is the same download and it works fine. So good in fact that I can't see what difference it made to anything.
  3. dengor
    dengor
    May 29, 2005
    im a complete noob....and will be getting a panny soon...so was wondering what you guy are updating and how?
  4. tichtich
    tichtich
    Dec 31, 2003
    476
    28
    Bristol, UK
    +33
  5. andrewb150
    andrewb150
    Feb 28, 2005
    87
    +6
    Cheers for that at least im not alone, Ive got a engineer coming round and hopefully he can force a new upgrade/downgrade of the software to get it working. I wont be happy if they want to take away the set and if they do they should give me a brand new one!
  6. SAMMYTHE
    SAMMYTHE
    Dec 31, 2003
    218
    Leeds
    +3
    Just spoken to Panasonic customer services regarding this problem and they are sending the "cam" so I can self-fix my TV.
    Not at all happy to have to chase first of all my supplier then Panasonic about an update they supplied that has crashed my TV. Anybody out there know my rights if the cam fails to correct the fault, I bought the set late March, can I return the TV for a full refund?
    Appreciate any comments.
