Panasonic TV's and NTSC (RGB) banding
Discussion in 'General TV Discussions Forum' started by Ged, Dec 28, 2004.
Tags:
  1. Ged
    Ged
    Apr 29, 2002
    943
    +24
    I have a problem with a Pioneer DVD player and the reported banding.
    Although this new TV is a Samsung LCD, the problem has returned, the original TV worked OK.
    I am worried that most cheap players are built around the same chipset and regardless of brand GUI are basically the same player.
    As price becomes an issue are all cheap players essentially the same?
    I would like to know if anyone has a cheap player with RGB scart not showing the banding problem.
    I do not want a Sony as the layer change is slow and -R compatability is poor, any ideas?
    Ged
  2. DJ Mike
    DJ Mike
    Nov 25, 2004
    412
    +19
    I got a freebie Sony DVP-NS355 with my Sony TV - while I don't use it as my primary player YET (because it has no multi-region capability out of the box), it does have exceptionally fast layer changing - haven't tested it for -R compatibility tho (I use +Rs myself).
    I say I don't use it much yet because I presently have a Pioneer that seems to have caused endless interference problems with my TV ;-) yet the Sony doesn't. Soon as I sort out a multi-region upgrade for my player the Pioneer will be relegated to the bedroom I think.
    M;.
  3. Ged
    Ged
    Apr 29, 2002
    943
    +24
    Thanks Mike,
    I eventually took the Samsung back as I wasn't impressed and had the option of a refund.
    I ended up with a Yamaha S550, which is made in Hungary but still had the issues, though less so in converted PAL mode.
  4. DJ Mike
    DJ Mike
    Nov 25, 2004
    412
    +19
    I get the feeling if you're using an LCD TV you should probably invest in a DVD player with a signal stronger than RGB - presumably your LCD set has component inputs? It might be worth exploring this avenue rather than trying to beat blood out of a stone with RGB.
    M;.
