Panasonic TV
Discussion in 'General TV Discussions Forum' started by steve k, Jul 22, 2001.
Tags:
  1. steve k
    steve k
    Apr 15, 2001
    713
    Birmingham
    +53
    Can anyone give me some advice on the Panasonic TV modle TX28DK1.
    My old telly finally gave out on me and the insurance company have offered me this modle as a replacement for £350.45, or I can upgrade to somethink else.
    The only thing I need to know is can you fit external speakers to this modle so I can widen the sound stage as I was able to do this with my old telly. :confused:
  2. steve k
    steve k
    Apr 15, 2001
    713
    Birmingham
    +53
    Another thing I need to know is what is the picture like from this TV
  3. Guest
    I guess the answer would be to try and find out how old the set is. I own a 25MK1 which is 2 years old. By the model no, I suppose your 28mdk1 is older. If so then it is not worth the price seeing as a brand new set is about £400 or so.
    If the tube isn't a quintrix type then give it a miss.
    [ 24-07-2001: Message edited by: Paul G ]
