Meridius
Hi all
Just a Quick question I am setting up a HTPC on Panasonic 1080p, 42" plasma and would like to know what 1080p pixel direct is ?
I have found out the RGB Full/Limited setting which limited been Normal setting. But is 1080p Pixel direct a ycbcr or rgb setting ?
so off is this ycbcr
and on is RGB ?
or the other way round or does that not have anything to do with that as I can not seem to find a setting in the tv for ycbcr or rgb hdmi input.
I have set the
PC to RGB Full
Software Player to Limited
TV set To limited which is normal on a Panasonic tv
to get the best from the HTPC for videos only
but I am not sure if its ycbcr or rgb on the TV ?
any help on this setting thanks
and on is RGB ?
I have set the
PC to RGB Full
