Panasonic TV & programmable remote question (PS12, pronto)
Discussion in 'General TV Discussions Forum' started by robin_wg, Jan 19, 2004.
Tags:
  1. robin_wg
    robin_wg
    Does anyone have any experience of recent Panasonic TV's and programmeable remotes (philips pronto or similar)? In particular I'm getting a TX28PS12 and I'm wondering if
    a) it responds to standard panasonic discrete power on/power off codes.
    or b) there's a workaround (like it comes on from standby if you press & hold '1' on the remote as many TV's do)
    c) does the selection of AV inputs follow the standard panasonic 'press TV/AV and then a colour' approach?
    If anyone knows the answer, or has time to quickly check for me, I'd be very grateful.
    cheers,
    Robin.
  2. deanjamin
    deanjamin
    Sep 11, 2003
    102
    19
    Nottingham
    I haven't used it with a pronto but I can tell you that my Marantz receiver's programmable remote can control the PS12 well.
    The selection of AV inputs does indeed follow the TV/AV then press a colour approach.
