panasonic TV plasma TH-42PX80BA
Discussion in 'Panasonic TVs Forum' started by agnjal, Feb 2, 2009.
  1. agnjal
    agnjal
    Feb 2, 2009
    2
    why after connecting a new Silver Crest HDMI DVD player to my new panasonic Viera plasma TH-42PX80BA via the scart socet the picture is green? Can anybody help? With my old Bush DVD player everything was fine.
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,293
    2
    137
    Airdrie, Scotland
    +1,079
    Hi, and welcome to the Forums.
    Sometimes, this kind of thing can happen when the scart connector has not been pushed fully home - it's worth checking.
    Cheers,
    Martin.
  3. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    I had this a lot when installing cheaper DVD players with Panasonic TVs. They just don't like playing ball together unless you remove the RGB status pin from the SCART lead.
    From memory, I think the RGB status pin is number 16. Its easy enough to remedy the situation, just unscrew the cap on one end of the SCART, find wire 16 (Google a diagram) and snip it.
    Replace the cap, and plug it back in. You'll find that sorts it. We used to get that problem all the time when plugging the likes of Philips and other cheap players into Panasonic TVs.
    Of course, it is possible (like mjcairney says) that the SCART could just be loose, so try making sure it is properly seated at both ends first. I suspect you will need to remove the RGB status pin though.
  4. agnjal
    agnjal
    Feb 2, 2009
    2
    Thanks! I've tried that and it seems to be working:smashin:
  5. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    No problem. Glad I could help. :)
