MikeMadDog
HI, I have a trio of Panasonic kit, bought because I thought the Viera Link would make things easy.. Wrong!
I have a TXP42G10B Plasma TV, SA-BT205 Blue Ray Cinema and a DMR-XS350 DVD/PVR. The DVD is connected via HDMi 1 and 21 pin scart as per manual to the TV, Blue Ray connected via HDMi 2 to the TV. Both leads are V1.4 after finding V1.3 doesnt work!
I have reset the DVD control to channel 3 and the Blue ray to 2 so they dont work each other.
The blue ray player when switched on and playing, with the tv switched to av 2 shows no picture on the tv but you can hear its playing via the cinema speakers.. have tried changing settings but to no avail.. any ideas that might sort thsi problem? cheers
