Panasonic TV and Sky Remote
Discussion in 'Sky Digital TV Forum' started by martin day, Apr 28, 2003.
  1. martin day
    martin day
    Mar 7, 2003
    214
    16
    Hi there,
    Just bought a new Panasonic widescreen TV and linked everything up to my Digibox (also Panasonic), VCR (panasonic) and DVD(pioneer).
    Everything works fine except for the volume button on my Sky remote and strangely enough on my OFA6 remote the volume button when I am in satellite mode.
    I also know of someone else who has had this problem but they just assumed it was a problem with the Sky remote until I mentioned it.
    The only thing we can think of that might have something to do with it is the Qlink feature?
    Does anybody have any experience of this and know of a fix maybe?
    Martin.
  2. Fernsehman
    Fernsehman
    If your TV set is compatible with the Sky remote (did you ask when you bought it?) then it will require you to enter the appropriate code. Lots of info here:
    http://www.satcure.co.uk/tech/digicode.htm
    If it's not compatible then the Sky remote will not control the TV volume.
    Fman
  3. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    what tv do you have
    I used to own a tx32pb50 and never had a problem getting the sky remote to operate the tv , I don't think the type of sky box makes any difference as all the sky remotes are the same (obviously the sky plus ones are different)
