Panasonic Tuner for PW5
Discussion in 'Plasma TVs' started by SherrifJWPepper, May 14, 2003.
  1. SherrifJWPepper
    SherrifJWPepper
    Foolishly :suicide: I brought the tuner to use with my screen. Im using RGB Freeview box for TV. The Tuner and freeview are in another room, linked to the screen by panasonics proprietry 15m lead. All Im using the tuner box for is an expensive scart switch. When using the tuner input card you loose the VGA input on the screen, can I assume that the tuner is using VGA?
  2. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    I think on the series five the tuner takes one slot, and you can't use the VGA input at all unless you disconnect the tuner.
    Bummer, eh?
    All the best,
    Dr John Sim.
