Panasonic TUCTH100 HD DVD recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lizzybif, May 6, 2005.
  1. Lizzybif
    Lizzybif
    Apr 12, 2005
    680
    +39
    I was going to get the Panasonic DMRES10 but have been told by a local retailer that if I get the Panasonic TUCTH100 that I can record Freeview on it and watch another Freeview channel on my TV through the Humax box I have.
    Is this true? :confused: If it is I would appreciate reviews.
    Liz
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes that is true, the TUCTH100 is a PVR with Freeview and a HDD.
    But of course, you won't be able to make a DVD, unless you get the DVD recorder as well. If you never will want to create a DVD to keep something or share with others, and just want to timeshift, then the PVR route is a good one. I haven't seen reviews of this particular unit, but would expect it to be good.
    Mark
  3. Oldjim
    Oldjim
    Oct 29, 2004
    77
  4. Lizzybif
    Lizzybif
    Apr 12, 2005
    680
    +39
    Thanks both!
    I've decided against it.
    Appreciate your advice.
    Liz
