Panasonic TUCT20 Radio services software upgrade
P
Panasonic
TUCT20 Software Update
Panasonic is pleased to announce that there is now a software upgrade to refine the operation of radio channels on your TUCT20 Digital Converter Box. The new software version number is 1.12 and it replaces the old 1.7 version software.
This upgrade will be in the form of an over the air software download. These are scheduled to take place as instructed below...
From 1000 on 18/11/02 until 0900 on 21/11/02 - Panasonic - Confirmed
From 1000 on 28/11/02 until 0900 on 1/12/02 - Panasonic - Provisional
From 1000 on 7/12/02 until 0900 on 12/12/02 - Panasonic - Provisional
Please not the dates given are provided by the broadcaster and are subject to minor changes at their discretion.
To receive this software download you must...
1. Ensure that your TUCT20 is turned on and connected to an aerial feed
2. Select a BBC television Channel (except BBC4)
3. Press the setup button on the remote control, scroll down the menu and select 'Software Update'
The following message will be displayed
New Version Found: - Do you really want to update the software and reboot the system? "Select the options"
4. Select 'Yes' by pressing the 'OK' button on the remote
Warning! System software is now updating. Please do not switch off STB!
Followed by
System software download in progress! This will take about 15 minutes.
Thank you for your understanding on this matter.
A
aqureshi
I also have panasonic Digital box but the model no is P2.2.52. My S/w version is 1.2s4bj and EPG vesion is 3.0.11.
Do u know if need to upgrade for my panasonic box. How can I find out if this s/w version is the latest .
