Panasonic TU-PT600B
Discussion in 'Plasma TVs' started by j.moghisi, Apr 17, 2005.
  1. j.moghisi
    j.moghisi
    Apr 11, 2005
    34
    Is the Panasonic TU-PT600B any good?
    It would be much cheaper than getting loads of terminal boards, JS Converter etc.
    I believe that it supports Component and RGB inputs, which is excellent, but it will also save me buying a Composite Terminal board for the VCR...Or is it still worth having a JS Converter in the setup (the expensive route)?
    Thanx
    Bye
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    well it was a £600 option (inc card and cable which you need) now £200ish, but its crap get a dual slot board and JS RGB>VGA much better and more flexible
  3. Enquirer
    Enquirer
  4. j.moghisi
    j.moghisi
    Apr 11, 2005
    34
    Sooo.........I think I'll stick with the Converter, Component Board, and Composite/S-Video Board).
    The screen comes tomorrow btw!! Can't wait!
    One last thing. Does the JS Converter automatically switch between 4:3 and 16:9? and will I really see a big difference with this rather than the scart board, especially since I can't do any colour adjustment (so I hear) when using the JS?
    Ok, so maybe that was more than 'one last thing' but anyway....
    THANKS YOU GUYS!!!
    cya
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    try a search, the fact that the JS doesnt auto aspect switch and that you dont get colour control (because you dont need it) has been covered many times, also see posts by TeressaTT and lisag for "whether its that much better than the scart"
