Panasonic Tu-dsb31 Rgb Problem
cdave
After my previous post "sky reception problem" and the comments about RGB problems on this unit, it seems worthy of a thread alone (I think). Does anyone with this unit know why it has problems with the picture going into "blocks" in RGB mode but not PAL. I hve tried all the various suggestions so far but no success. May be no answer at all but if anyone has cured it let us know.
Previous post
http://www.avforums.com/forums/showthread.php?threadid=59381
gringottsdirect
I have one of these, connected by RGB, it works fine, I've seen no references stating contrary in any forum.
Maybe it's a faulty box or scart lead ?
grumpyguy
I also have this box, and it also plays up in RGB. i recently slightly adjusted my sky dish and the signal quality dramatically increased. In turn I now have less breakup when in RGB, and can now watch most channels problem free.
cdave
Glad you have no issue but have you looked at the link on my message.
:confused:
gringottsdirect
:confused:
Hi cdave,
I read the posts in your link.
I tried a couple of different scarts with the channels mentioned, my box is O.K. with RGB.
Sorry I can't help .
M
mrouse
I don't have this problem, with my box. I am however trying to ge the sound form my digibox to be output through my amp. I am currenly using the audio out sockets straight into my amp, but I am getting some distotion from my rear speakers when trying to output Pro Logic II. Thanks in advance
Similar threads
