Panasonic TU 600 -> PW5 cable
Discussion in 'Panasonic TVs Forum' started by fmottaz, Dec 25, 2002.
  1. fmottaz
    fmottaz
    Aug 31, 2002
    Switzerland
    I would like to know if this cable is standard, if it can be replaced or extended with an equivalent PC display cable. I need to gain some space behind my tuner box and the supplied cable is very stiff. I cannot bend it enough in its present form.
  2. ijwoo1
    ijwoo1
    Sep 29, 2002
    Billericay, Essex
    I believe a 15m cable is available as an option. BTW its not a standard VGA cable.
  3. Private Penguin
    Private Penguin
    Panasonic can supply the 15m cable for £134+VAT and shipping. I have one running up an empty cavity wall, across the loft and down the chimney!
  4. fmottaz
    fmottaz
    Aug 31, 2002
    Switzerland
    Thnaks all for the replies but my problem is not length but stiffness. I would need to bend the cable (due to space problem in my cabinet) and the Panasonic cable is very stiff. I wondered if another cable could be used instead. This would mean I could look for a softer one.
  5. franc
    franc
    Sep 12, 2002
    450
    Bucks
    +7
    Hi, I know this is kinda off thread but can you tell me what buttons are on the fascia of the panasonic 600 tuner unit? Also, if you or anyone else can also tell me the buttons on the fascia of the 300 version I would most appreciate it.
    thanks FRANC
  6. allanrose
    allanrose
    Dec 14, 2002
    38
    store, function, channel -, channel +, tv/av
  7. franc
    franc
    Sep 12, 2002
    450
    Bucks
    +7
    thanks
    FRANC
