M
maralv
Has anyone been able to upgrade the drive on their dvd recorder. does anyone know how the disk is formated. Pioneer seems to have a utility to format the hard drive if needed. Anyone know if it would allow you to install a bigger drive I am currently looking at the following units RDXS32 DVD520H DMR-E85HS HAS ANYONE HAD ANY LUCK UPGRADING THEIR HARD DRIVE
