Panasonic TH42V500 - Optimising PQ with DVD and SKY for a novice
Discussion in 'Plasma TVs' started by golfnet, Aug 30, 2005.
  1. golfnet
    golfnet
    I have just bought a Panny TH42PV500. I watch only Sky digital and DVD. What connections should I use to optimise picture quality for both these sources. I am a total novice and have not got a clue so not too much techno jargon please. Do I need to buy extras to optimise these. If so what are they? Also, buying a new DVD player ..... which one will go best with the Panny .... dont mind cost ... want quality.
  2. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    Where did you get it from m8? and how much did you pay. im looking to get one in the next month, hopefully the price drop happens by then.
  3. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Make sure the SKY box output is set to RGB output and 16:9 (go to the SKY System menu). Then use a fully-wired Scart from the RGB output of the SKY box to the AV1 (RGB) scart input of the PV500. The DVD can either be component to the component inputs or RGB Scart to the AV4 (RGB) input.
    Remember to set the Picture settings for ALL inputs separately - to start with keep them all on Cinema with brightness and contrast below half way.
    Hope this helps.
