Panasonic TH42PZ80 PC connection missing
Discussion in 'Panasonic TVs Forum' started by AFHwires, Jan 11, 2012.
  1. AFHwires
    AFHwires
    Jan 11, 2012
    Trying to help a friend connect his laptop to a Panasonic Plasma TV TH42PZ80. We used an standard analogue "SUB-d" cable used to connect PC monitors to PC's. This was plugged into the socket marked PC on the back of the TV. From the remote we pressed "AV" and a list of AV connections was displayed. The manual states that there should be an entry entitled "PC", but there wasn't (?) Needless to say we could not display the Laptop screen on the TV. The "HDMI3" connection was also missing from the list despite there being a socket so marked. Tried different power up sequences ( TV - Laptop; Laptop - PC) but to no avail.
    I have used this type of cable to connect laptops and Pc's to Sony TV's via the SUB-d connector and they worked fine first time.
    Any thoughts? Does your TH42PZ80 show a PC connection on the AV list?
  2. StevieBuck
    StevieBuck
    Jul 7, 2007
    3,723
    Aberdeen
    +672
    My guess is that the PC and HDMI 3 inputs are “hidden”.
    I can hide any of the inputs from the source list on my own Panasonic by going to Menu > Setup > Display Settings > Input Labels and then choosing “Skip” for the label. Setting it to anything else will make it re-appear on the AV source list. I imagine he'll have the same option on his TV.
    Basically it allows you to disable the inputs that you don't use, allowing you to cycle through the ones you do use more quickly.
