panasonic TH42PZ70B .. memory card question ?
tabs
just got my TH42PZ70B yesterday, just a quick query regarding the memory card slot, can it only be used for photos or is it possible to watch a film ect via the memory card ?
thanks
pjskel
Try it and see - it won't break the TV.
Suspect you can since the various cameras that take SD can also do video.
tabs
cheers, i just didnt have a memory card, and didnt wanna buy one to find out it wont work then have no use for it afterwards :)
fairly sure that it will only show JPg files. previous models have had support for movies. on some you could record tv directly to an sd card
JVC 4K projectors, Denon X3800 & Perlisten speaker reviews, adding a sub to 2-channel + AV/HiFi news
