panasonic th42pz70 switching source
Discussion in 'Panasonic TVs Forum' started by techmob, Sep 15, 2007.
  1. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    i am sure my tv used to auto switch source, for example if i am watching sky which is connected by an RGB, if i then switch on my xbox 360 which is connected by hdmi the tv will auto switch to this source and display the xbox360, the same would happen if i then turned off the source, it would revert back
    but i am not getting either to work, i have to manually select the source and manually switch it
    any ideas?
  2. yetanotherbob
    yetanotherbob
    Mar 22, 2007
    637
    28
    London
    +55
    What normally happens with pannies is that after a source has been manually selected the auto switching stops working.
    If you switch off the TV (not just put on standby) and switch it back on again the auto switching should be active again.
    Bob
  3. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    thats so annoying, any way around it other than the obvious ( dont manually switch)
    but thanks for that, i will try that later
  4. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    just to bump this thread as i did forget about it, as the above advice does work.. or well did..
    i think i may have a fault on my tv, can anyone comment!
    hdmi 2 is not auto switching anymore, hdmi 1 does
    i have a sky hd box and xbox 360 elite, and both boxes auto switch on hdmi 1, but neither auto switch on hdmi 2
    i have turned the tv off and on, i have reset the tv to factory default and nothing is making anything auto switch on hdmi2
    is this a fault on the tv?
    should i contact john lewis as it is obviously in warranty?
  5. JayQ
    JayQ
    Jul 10, 2006
    69
    +17
    On mine my DVD Player connected to HDMI 1 Auto-Switches, My PS3 connected to HDMI 2 does not.
    Hope this helps.
  6. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    hi
    hdmi 1 and hdmi 2 has always auto switched up until now!
    honest i am not going mad (i hope)
  7. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    i must be going mad
    i contacted panasonic about it, as i am pretty sure both of my hdmi sources used to auto switch (although there is a chance i am going crazy, as i have added an amp to my setup and changed about a few times)
    this is the response i got from panasonic
    according to them neither hdmi sources auto switch, which leads me to beleive myself that both hdmi sources auto switched at one point
    maybe it was a fluke, or maybe this means that hdmi 1 will stop auto switching soon and back up panasonics theory
