Panasonic TH42PX60PED DVI/Analogue Issues
kpkpkp
Ok Guys I need help.
I have a Panasonic TH42PX60PED that I have just set up. There is a 10 meter DVI male - DVI male cable in the wall there it is situated. I have an analogue D-SUB port on the back of the plasma and I have been trying to get the a converter for the cable - every time I buy a converter (I am on my 3rd now) I just keep getting no signal - it must be something to do with how the internal wiring of the converters are wired - anyone else had this sort of problem on any TV and anyone found a solution.
Thanks in advance
Kp
bu5ter
Have you tried a dvi->hdmi converter instead not tried this myself but might work if you get the right resolution
