Panasonic TH42PWD7B
Discussion in 'Plasma TVs' started by AFCB01, Jul 8, 2005.
  1. AFCB01
    AFCB01
    Have just bought this plasm panel recently and have set it up through a Pioneer VSXC402 Amp/Receiver connected via an J & S converter (linked to Sky Plus and a Panasonic E50 DVD recorder)
    I was wondering if somebody could suggest the best settings to use for the best picture and to avoid any screen burning etc in the early stages of use
    Any help greatly appreciated
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Just get the contrast and brightness to zero, which is the middle of the range. You are highly unlikely to burn this screen, and these settings are in fact quite close to where they will be when you run the THX setup or DVD discs a bit later.
