Panasonic TH42PW7B HTPC
Discussion in 'Plasma TVs' started by StormReflex, Nov 20, 2004.
  1. StormReflex
    StormReflex
    Is the Panasonic TH42PW7B ideal as a HTPC ? What resolution will it accept from the PC ?
    I know its native resolution is 852x480 which aint much use for the PC desktop, I would like to use 1024x768 minimum in good quality with legible text for web browsing etc, will this Plasma cope ? Also can you get a DMI card for it and what resolutions would work with that ?
