Panasonic TH42PW7B. HD Compatible?
Discussion in 'Plasma TVs' started by OvertoneBliss, Mar 4, 2005.
  1. OvertoneBliss
    OvertoneBliss
    Erm, I think I did something stupid.
    I just ordered the Panny PW7 but I'm not sure how it'll do for use as a PC monitor or even if it is HD compatible.
    Nevermind. I only ordered it via finance so I can just cancel if it isn't.
    If it isn't HD compatible then what other monitors plasmas are (same price range)?
    Thanks,
    Phil.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    No sub £1500 plasma is HD compatible (EICTA HD Ready soecs) Panny can be made HD compatible and as for PC use see posts be lisag..........try a search for PW7 and PWD7.......
