Panasonic TH42PV500CAB full info NOW
Discussion in 'Plasma TVs' started by greyhorse, May 8, 2005.
  1. greyhorse
    greyhorse
    Apr 16, 2005
    445
    106cmV 16:9 Widescreen Panel
    Viera Colour Management System
    HD Panel
    SD Card Slot
    Freeview
    Product Description
    106cmV High Definition Viera Plasma Television plus Cabinet Stand
    Panasonic takes a leap into the future with the new PV500, as it proudly launches a fusion of superb colour management technology and high definition broadcast capabilities - all encased within the stunning signature design of the classic VIERA.
    For the very first time, Panasonic has twinned its award winning VIERA technology with the hugely desirable capabilities of high definition. The new G8 HD panel is capable of displaying high definition images which are impressively detailed and defined - they are sure to blow you away. With the easy to use HDMI connection, HD pictures can be displayed on the 42 inch screen, whether this be from a high definition DVD source or HD television broadcast, producing the most vivid colours ever experienced on a VIERA. With the announcement from BSkyB that they are planning to go live with HD broadcast in 2006, the PV500 series looks set to be the most rewarding purchase you can make this year.
    Outstanding contrast
    In addition, to further enhance the picture quality, the new G8 HD panel uses a highly efficient discharge gas that lights at lower electric power levels. This technology allows the TH-42PV500 to produce even brighter pictures. Outstanding contrast is achieved, with the panel boasting a rise in brightness of up to 10% - helping to establish the new G8 HD panel as one of the most significant additions the Panasonic portfolio has seen.
    Over 5 billion more colours
    An amazing 8.6 Billion colours come alive on the TH-42PV500 - that is over 5 billion more colours than Panasonic's previous VIERA models. This new series marks a milestone in picture quality, boasting up to 2048 levels of gradation, enabling the equivalent of 8.6 billion colours to be produced - all thanks to the new VIERA Colour Management System. The result is dark areas that are more clearly defined and a picture quality that is greatly improved. Every aspect of the movie will be there in full glory, on the big screen, with every action packed shot clear to the eye - you will see exactly what the director wanted you to see.
    Technical Specifications
    tv tuner
    Tuner Integrated
    Yes
    DVB Digital Tuner
    Yes
    Tuning System
    PLL synthesizer 100-position auto-search tuner
    Broadcast Stereo Reception
    NICAM (FM)
    Fastext
    2000P Level 2.5, FASTEXT/LIST/TOP
    Receiving System
    PAL -I, DVB, AV-NTSC: PAL-525/60, NTSC, M-NTSC
    display
    Screen Size / Screen Aspect
    42inch (106 cm) diagonal
    Panel
    G8 Progressive HD Plasma Panel
    Number of Pixels
    786,432 (1,024 x 768) pixels
    Applicable PC Signals
    XGA (SXGA, UXGA compressed)
    Displayable Colours
    3.6 billion colours for full-time/full-pixels, Max 8.6 billion equavalent colours for darker part
    Contrast Ratio
    3000:1
    sound
    Speaker System
    Smart Sound Speaker System
    Speakers
    Woofer (80 mm round) x 2 (L, R); Tweeter (16 x 73 mm) x 4 (L, R)
    Audio Output
    26W (13W x 2)
    Ambience
    Yes
    terminals
    SD Memory Card Slot
    Yes
    PCMCIA Card Slot
    Yes
    Composite Video Input
    AV3: RCA phono type x 1 (front)
    S-Video Input
    AV3: S terminal x 1 (front)
    Audio Input (for Video)
    AV3: RCA phono type connectors (L, R) (1 set, front)
    PC Input
    Mini D-sub 15-pin x 1 (rear)
    Audio Input (for PC)
    RCA phono type connectors (L, R) (1 set, rear)
    Component Video Input
    RCA phono type x 3 [Y , PB (CB), PR (CR)] (rear)
    Audio Input (for Component Video)
    21-pin Input/Output
    AV1: AV In, TV out, RGB In (rear), AV2: AV In/Out, S-Video In, Q-Link (rear), AV4: AV In/Out, S-Video/RGB In, Q-Link (rear)
    Audio output
    features
    Screen Saver
    Side Panel Adjustment
    Multi Window
    PIP/POP/PAT
    Aspect Controls
    Panasonic Auto/16:9/14:9/Just/4:3/Zoom1/Zoom2/Zoom3
    general
    Power Supply
    AC 220 - 240 V, 50/60Hz
    Dimensions (W x H x D)
    1138 x 730 x 138 (panel part: 98) mm
    technology
    HD READY LOGO
    DVB LOGO
    FREEVIEW LOGO
    REAL MACH LOGO
    VIERA LOGO
    http://www.panasonic.co.uk/plasma-tv/th42pv500cab/index.htm
    A good sign its on its way :) :smashin: :smashin:
  2. carlton
    carlton
    A link to panasonic uk would of done :D
  3. greyhorse
    greyhorse
    Apr 16, 2005
    445
  4. greyhorse
    greyhorse
    Apr 16, 2005
    445
    some may of needed info sooner than a link :D :D :D :D :D
  5. daveblade
    daveblade
    Apr 2, 2005
    333
    +13
    good work not too long now
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  7. llg
    llg
    that offer aint bad though i can get it for £2599.99 i know more exspensive but also get wall bracket free dmres10 and five year warranty and avaliable to buy on 24 months ifc.
  8. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    So which is the HDMI connector?
  9. TheGworks
    TheGworks
    Apr 14, 2005
    54
    +12
    Anyone know if there will be a TH50PV500CAB version?
  10. dino25
    dino25
    yes there will be a 50PV500CAB version
