Panasonic TH42PV500B Which Shape ?
Discussion in 'Plasma TVs' started by Korum, May 19, 2005.
  1. Korum
    Korum
    Feb 19, 2005
    4,226
    Stockton-on-Tees
    +666
    I'm interested in the TH42PV500B but trying to find out what shape housing it comes in is very hard.On Panasonic UK's site the shape of the PV500 is exactly the same as the PE50 but on European and US Pani sites the shape of the similar model is the same shape as the older PE30.
    Has anyone seen a UK spec PV500 to determine definately what shape it is ?
    It's important to me as I want to wall mount it and the PE30 shape looks like it may look slightly odd on the wall because it's quite deep but on the otherhand whilst the PE50 is slimmer the matt black housing and bottom speaker grills make it look quite cheap, not what I'd be looking for if I'm forking out 2.5k.
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,990
    2
    4
    137
    Garstang, Lancs
    +1,571
  3. Korum
    Korum
    Feb 19, 2005
    4,226
    Stockton-on-Tees
    +666
    Thanks, so is that the exactly the same shape as a 42PE30 with gloss surround etc as the av sales image isn't too detailed.
    Are there any links which show the PE30 wall mounted taht you know of ?
  4. alliwant
    alliwant
    i think it its still the slimmer version without the curve at the bottom...from what i can make out
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,990
    2
    4
    137
    Garstang, Lancs
    +1,571
  6. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    The Panasonic UK website's cabinet pics are correct but all the other pedestal, panel only pics are of the PE50.
