panasonic TH42PV500B & my xbox
Discussion in 'Panasonic TVs Forum' started by Mr_Tony, Aug 10, 2005.
  1. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    I set up my panasonic TH42PV500B yesterday and everything is fine apart from the picture on my xbox, i have sky in the 1st scart, dvd in the 2nd and my xbox in the 3rd...but i have no picture....anyone know why?
    thanks
  2. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Ist and 3rd Sockets are RGB, Are you using just a composite lead on the Xbox ? Maybe you can only use RGB on socket 3.Try it in Socket 2 if it doesn't work sounds like a faulty lead.
  3. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    oh right ok cheers, ill have a look
  4. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    ive changed it over and i put the dvd into the 3rd scart socket, then no picture came through, what needs to go in there from my dvd player in order for it to display?
  5. MrNPG
    MrNPG
    Apr 13, 2005
    777
    Poole, Dorset
    +63
    If the DVD is now plugged into AV3 (which I believe is one of the RGB scarts) then you should change your DVD players settings to output an RGB signal.
  6. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    oh right thanks for your help
  7. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Tony, Hope you sorted your connections out.If I had your setup I'd buy an advanced scart lead for the xbox and connect it to AV4 (3rd scart lead) as you are wasting the PQ of your PV500 by using composite.You could also get the component Kit for the Xbox, you at least want an RGB connection on it.Is your Xbox modded at all, if it is you can use the component for progressive scan, it looks brilliant on the PV500.
    With regard to your DVD, Has this got component out or the ability to select S-Video out through AV.This last option will be on the settings menu on the DVD player.
    What I'm trying to say is composite PQ is terrible and if possible you should avoid it completely.BTW have you enabled RGB on your Sky Box ?
  8. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    AV4 Korum?
    I do have the advanced scart cable, and my dvd player is the Panasonic DMRES10, my xbox isnt modded though.
    I have telewest digital not Sky......
    cheers for your help
  9. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    AV4 Korum ? come on Tony you must be able to work this out in the manual.
    AV1-RGB scart on back of set
    AV2-S-Video scart on back of set
    AV3-Composite/s-video on the front of set
    AV4-RGB scart on back of set
    If you plugged in an advanced scart lead into the 3rd scart socket (AV4) on the back of the PV500 it would have been RGB so you've either got a faulty Xbox lead or there is something up with the scart connection.
    Just a thought Tony,you're not actually selecting AV3 thinking it's the 3rd scart are you ? This TV has awful AV selection hasn't it, you would have thought AV3 would be the 3rd Scart and I wont even go into how to select the AV channels on the remote.
  10. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    its all working now, the xbox is in the 3rd socket... dont know why it didnt work the other day..
    instruction manuals?? what are they ;)
