Panasonic TH42PV500 won't talks to DVD
Discussion in 'Plasma TVs' started by Kefre, Jul 8, 2005.
  1. Kefre
    Kefre
    :lease:
    Hi there,
    I know this may be a simple question, but I really would like to watch a move this weekend on my new plasma TV. I am trying to connect PV500 to Yamaha DVXS200 home cinema system, using component cable... but, I can't get the TV to see the DVD. I read the whole manual and it is simple to identify component connections, but can't get it to work. So, help please...
    thanks
  2. Moncs
    Moncs
    Jan 14, 2002
    460
    Edinburgh, Scotland
    If the Yamaha is anything like my Denon system was, you have to connect it via SCART first of all, as the default settings on my denon was SCART.
    Then you can access the setup menu and change the output to component.
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    that is usually the case
  4. Kefre
    Kefre
    thank you :)
    OK, i am going to get a SCART and try it. Sorry, if I sound like a complete stupid, but after that, do I change the default menu on Yamaha (if yes, how?) or on plasma?
  5. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    yes hook it up by scart change the yammy video settings to component out and you may have to set input on the screen to component too
  6. Kefre
    Kefre
    thanks Mep - have a nice weekend
  7. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    and you mate
