Panasonic TH42PH9
Discussion in 'Panasonic TVs Forum' started by bytesize, Jan 1, 2007.
  1. bytesize
    bytesize
    Aug 11, 2006
    378
    Exeter
    +8
    After reading through various threads on here regarding the Panasonic TH42PH9B Plasma screens - I am still 50/50 on upgrading to this model from my PWD6 .. will the benefits be worthwhile ??
    I intend on running the following kit
    Xbox 360 - Component
    Xbox 1 - Component
    Wii - Component
    Sky HD - Component or HDMI - (Which gives the best picture)
    Windows XP MCE via VGA on Panel
    Any advice would be welcome. Have a new Sony AMP with component and HDMI inputs / outputs so should be ok .. just more interested in the screen itself
    Any PH9 screen owners care to comment, as to be honest my PWD6 is still pumping out a great signal / display even from Sky HD ...
    As for my PWD6 - thinking about installing it in my office ...
    Regards and happy new year
  2. jimborae
    jimborae
    Sep 16, 2004
    1,318
    2
    2
    Berks
    +108
    Personally I wouldn't bother. I have a PH9 and while the picture is excellent I certainly wouldn't be able to justify the cost of upgrading from a PWD6.
    We have PWD6's at work so I know how good the picture is (especially with SD) so if HD still looks good on it then no way would I upgrade.
  3. sdb123
    sdb123
    May 17, 2005
    18,181
    2
    Rushden, Northants
    +2,252
    I'd only suggest upgrading if you go for a bigger display or have a majority of HD equipment.
  4. bytesize
    bytesize
    Aug 11, 2006
    378
    Exeter
    +8
    Views noted, thanks.
