Panasonic TH42PE40B
Discussion in 'Plasma TVs' started by Genesis, Jun 29, 2005.
  1. Genesis
    Genesis
    Aug 11, 2004
    196
    +3
    What it the difference between the TH42PE40B and the TH42PE50B. As usual the assistant in curry's had no idea what the difference was. :confused:
  2. Anthall
    Anthall
    Oct 27, 2004
    219
    Kettering
    +4
    Are you sure its not the PE30B they had n not a 40?
    Lots of differance, but because i have a 30B my biast view is
    that they removed alot of the specifcation to make the 50 cheaper
    than the older 30. And then gave the 50 a half hearted HD ready
    to justify the update.
    But im an idiot and biast.
  3. cpt1979
    cpt1979
    Mar 6, 2005
    1,411
    48
    Brighton
    +41
    I've also seen this PE40 in Dixons, when asked the difference between PE30 and PE50 the assistant didn't know what i was on about! and asked whether they were also both 37".
    From observation the 37PE40 is an ugly version of PE30, it has a full silver surround and none of the black gloss.
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,062
    2
    4
    137
    Garstang, Lancs
    +1,597
    Check the model number on the back, it will probably be the 50B
  5. Genesis
    Genesis
    Aug 11, 2004
    196
    +3
    I checked the back at the time and guess what "TH42PE40B". They do exist ! :confused:
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,062
    2
    4
    137
    Garstang, Lancs
    +1,597
    Very strange :confused:
  7. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Strange indeed! Just checked Dixons website and they have the PE40 listed but without a photo/image. Maybe it's a Dixons' exclusive model? :confused:
    S.
  8. swartzy
    swartzy
    Apr 16, 2001
    9,286
    Northern Ireland
    +660
    possibly made in Germany
  9. GedF
    GedF
    I thought the PA50 was the european model?
  10. dempsey
    dempsey
    You are quite right, this model is an exclusive to Dixons store groups.
  11. andye2004
    andye2004
    Sep 11, 2004
    689
    28
    +31
    Lots of high street retailers do this kind of thing. Guarantees they will never need to honour their "price promise"s, 'co no other retailer will have that model.
  12. BliarOut
    BliarOut
    If you go on the Panasonic website and download the manual, it's identical to the PE50. It's a TH42PE50B in everything bar name.
  13. Gussie
    Gussie
    Oct 19, 2004
    1,236
    48
    +80
    Just to confuse people more - it's likely that Panasonic will intro the PE55 soon - a PE50 plus HDMI interface.
    It's already been announced in Germany!
    Gussie :)
  14. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Ahh another mystery solved! :smashin: Thanks to Blair, I see panny UK have added a whole slew of manuals to their database for their plasma TV's up until a month or so ago the only one available for download was the PA20. Looks like they have added the PA30, PA40, PA50, PE40, PE50 & PV500. :thumbsup: Looks like the PE30 is still missing off the download database though :confused:
    S.
  15. alex_30252
    alex_30252
