Panasonic TH42PE30B vs TH42PA30
Discussion in 'Panasonic TVs Forum' started by wildcat42, Sep 22, 2004.
  1. wildcat42
    wildcat42
    It seems the only difference between these two models is the absence of a digital tuner in the PA30 (oh, and about £500). Would the learned members have any advice on picture quality of TH42PE30B vs TH42PA30 and external tuner box. Is it worth the £500 extra to have an inbuilt digi tuner?
    Thanks in advance,
    Wildcat42
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,635
    London
    +476
    The PA30 is not an official UK model. Post 12mths warranty you might get a bit un-stuck. A lot of extended warranties do not like to cover imported or grey stock.
