Panasonic TH42PE30B PC connection
Discussion in 'Panasonic TVs Forum' started by leighv, Sep 7, 2004.
  1. leighv
    leighv
    Apr 6, 2003
    47
    I want to connect my PC to my Panasonic - but I don't want to connect it through the front (where the VGA input is - who put that there???)
    So I have the option of SCART, component and s-video. Which would you all recommend?
    At the moment I have a VGA output on my PC, a s-video socket and that's about it. I can add a pci card - which would you recommend if I am trying to connect to my plasma for the best picture (I want to play DVD's through the PC on the TV).
    Thanks.
