Panasonic TH42PD50 with Shuttle PC
Discussion in 'Panasonic TVs Forum' started by akvag, Aug 11, 2005.
  1. akvag
    akvag
    Hello,
    I am buying a Panasonic TH42PD50 in the next few days.
    I want to hook this up to my Shuttle PC, as a HTPC.
    The 42PD50 does not have a VGA port, but can I purchase a DB15 to 3 connector component cable...http://store.a2zcable.com/v213-6.html
    Please advice.
    Thanks AV
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Wrong plasma to use a HTPC with. Best plasma for it is still definitely the Pioneer MXE1 in my opinion, but otherwise you need to look at the Panasonic monitors (42PWD7 low res and 42PHD7 high res)
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Agree completely, Liam. Don't bother with a plasma where you have to bodge the PC input. Ideally it should be native on DVI at 50Hz for HTPC use, hence the recommendation for the Pioneer 433MXE1, even the mighty PHD7 cannot do this.
  4. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,523
    Kent
    +830
    I would run the Panasonic analogue not DVI, better/equal results and accepts 50Hz no problem.
  5. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,523
    Kent
    +830
    But I would run the Pioneer DVI as on that screen the DVI is absolutely wonderful!!
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Just so, both are in front of me now, connected just as you say. From a scaler, not HTPC, but same principle holds. Yes, for signals accpted by the DVI, like XGA at 60Hz, you are very hard pressed to tell analogue from digital on the PHD.
